peterchurch said:Yes,
if you want to do this I would suggest that you talk to a company called Heyward and Scott in essex they will build you a custom exaust removing all the pesky bits in between...
They offered to build me the front section for about £400 but could be cheaper than that there is a company that will do this in Birmingham as well.
Now the downside...
If you do it then you will need to retune the engine and maybe reprogram the ECU. If you don't the car could attempt to run on a very lean fuel mixture. This in turn can lead to holes in the pistons and early death of the engine
I was thinking about doing this on my car following the failure of one of the cats last week. But I decided that risking my engine was not worth it when I can get a decent cat for £300
Best regards,
Peter
190 said:Peter that is the reason for the lambda censor being fitted. Is to monitor the exhaust gases and get the required burn mixture so as not to damage the cat. There is no difference to the cars running with the cat removed. The only downside is the MOT If your car was registered after Aug 1992 [K-REG]
