lambo911
Hi All,
My 1982 500SL it starts fine and idles ok at 650 rpm but the exhaust smells of fuel. When accelerating from low rpm it bogs down a bit but as the rev picks up it is fine. The oil smells a bit petrolly as well.
The cold start valve is working ok and not leaking. And as the idle is fine I don't think it is a vacuum leak.
I am thinking it maybe the injectors leaking and they are probably the originals looking at them, they are Bosch 0437 502 010 and are grey in colour.
Do you think I should just change them all anyway ? They are about £40 each and I'll need the rubber seals too so not cheap to do if that isn't the problem.
Cheers
Richard
Cheers
Richard
