r107 abs sensor NLA
Rohan
r107 1984 280sl manual
Hi all, I managed to break one of the abs sensors while trying to clean it - note to thers - remove the brake disc to clean the sensor rather than try to remove the sensor from the suspension leg!
It comes up as part 107 540 0017 or bosch 0265 001012 and then some other manufacturers but prices are very high and availability seems very limited! Looking at $300 fro one from the US that is non Merc/Bosch.
Sl shop has them listed at an eye watering £500 but not available anymore.
https://www.theslshop.com/mercedes-benz-sl-107-slc-abs-sensor-1075400017.html
Does anyone know if one from a w126 will fit? It looks the same and as long as resistance is similar I guess it might do.
Any help would be great - thanks
Rohan
rayhennig
1991 300CE-24 Sportline
Rohan
How about here:
https://www.onlinecarparts.co.uk/oenumber/a1075400017.html
RayH
R
Rohan
Yes i tried all of those RayH - none have any stock unfortunately. It looks like the w126 part has the same resistance and looks the same so may well work. Thanks!
rayhennig
daveenty
The Frozen North :(
2019 AMG S Class Coupe
You could always try Mercedes at Poole who tend to look after the heritage side of things. I don't have a website for them but their excellent, as opposed to most of the monkeys I usually deal with, parts people can be reached on 01202 902 057
R
Rohan
Thanks everyone - following up on all these right now! Much appreciated. Will update how I get on.
R
Rohan
Waiting to hear back from Ray Hennig's suggestion but from Merc it is on backorder and unlikely to do a run the helpful chap at Poole dealership said so the hunt goes on!
R
Rohan
Yep - no availability anywhere - seems the w126 part has the same resitance and looks similar so I will try one of those and report back.
Peter Marchant
Mercedes RHD 380 SL 1982
Hi Rohan,
I am having the same problem and am looking for an RHD 380SL 1982 drivers side ABS sensor could you advise if the w126 one worked??
Kind regards
Peter,
R
Rohan
No it was slightly different Peter - I am still looking!
