Picked up the car after the starting problem had been rectified (see other thread!) ... driving down M3, smoke from both rear wheels, forced to pull over ... discs glowing! Limped home.
Inspection shows that both calipers had got extremely hot! Pads worn down to metal & distorted, piston boots carbonised/vapourised! Front brakes OK to stop vehicle. Once cleaned up, the drivers side caliper appears to have a hairline crack causing a small fluid leak. Passenger side OK.
Any ideas???? It had a full service at Hughes MB less than 500 miles ago ...
HELP!
HELP!
