r129 1999 wing mirror glass removal
wub
chippenham
410d 2.9td 1990
I have something lose behind the drivers side glass on mine which rattles when going over bumpy roads and is very annoying. i want to either get the glass out or the plastic covers off to investigate. I have searched high and low on the internet and all video's seem to be of the earlier square shaped side mirrors. I have tried to prize the bezel off, but it dient want to budge and i diont want to snap anything. Can someone tell me how to take these later type side mirrors apart? thanks
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
iirc, you need to dip the mirror first. This gives access to the top of the glass. Behind it is a thin spring clip which you need to lift up to release the glass. You may be able to see the noisy culprit from there.
W
wub
chippenham
410d 2.9td 1990
Great thanks for the that
DREAMER NO2
W124 2.6E M103 1989
Was the mirror glass held in by a nylon knuckle the knuckle splits open as you pull the glass out .This was the old idea maybe its changed now ..Last time i had this tha glass had come of its holder and floating inside
