Please can some one help me with some advice .I changed the lock on the the drivers door and whilst changing it it blew a couple of fuses .1 was in the engine bay for the instrument cluster the other the drivers window .I replaced these and all seems to be fine but Since then i can't get the hardtop off .It will pull the roof down if the button is pressed forward .But when the button is pressed back it does nothing .I have reset the windows and the roll bar but still does nothing .The light flashes once to tell you that the system is ready and does nothing within the 10sec time fro turning the key to position 2 then the light constantly flashes when you hold it back .The only odd thing i have noticed is that the drivers window takes a long time to click when resetting it and the closing of the windows from the key works one day then not not .Is it poss that the eco is damaged on the window circuit and doesn't know where the window is so halting operation .Can anyone help me with a diagram of the connections to the ecu ( I'm an electronic engineer so if i had this would make life so easy ) I did take the hardtop off manually but the soft top did nothing
