SamT
- Oct 22, 2008
- SL320, 40th anniversary edition
I'm getting a rattle, or clanking in my SL320, somewhere behind me whenever I go over one of those short stone, or rubber speed bumps at very slow speed.
The rear subframe was recently overhauled, with new mountings, links & bushes and the only thing that I can see is odd is that there is the best part of 1/4" of play between the washers between the bolts and the underside of the subframe, where the mountings are fitted.
The washers are quite loose and sloppy on the shank of the bolts, so I wonder if the noise comes from here, when the subframe is jolted over a bump.
The bolts are tight in the subframe, but I am wondering if the unthreaded section is too long.
I can see that there will be some vertical movement in the bush, but this looks far too much and all wrong to me.
Has anyone come across this before?
