LAMPS
Hi, My problem is that the drivers side window will not close fully, it reaches the top and then seems to slip. Reading an earlier post it seems it could be the micro switch by the door handle. I have managed to locate on the site, the video of how to remove the door trim but I would be very grateful if somebody could point me in the right direction where the microswitch is before dismantling the door. I think it is also linked to another problem with the roof not retracting after removing the hardtop. I believe I need to carry out some resets, which one is reseting the windows, so I will need to sort that Problem first. I am fast learning it is a mine field out there.
Many thanks in advance,
Ian
Ian
