R129 SL320 1999 No horn mirrors indicators wiper
film cameraman
Registered
usk,monmouthshire,uk
SL320/1999/320
My car R129 SL320 1999, has the following not working....indicators, horn, mirrors, wiper, radio. ABS and SRS light on.
The car went into limp mode after the battery drained. Recharged and started engine. Went through the process of steering wheel indicators brake mirrors windows and rollover bar deployed. Did not work like it usually did.
The wiper came across the screen once and stopped in a raised position. None of the above can be re-tried as they are no longer powering up.
Having googled this and some other sites, it appears to be a fault with the N10 relay. Where is it located. I have included a picture of my fuse board with the cover removed. Please could anyone identify the position of this relay.
Many Thanks
Mike
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
You could try disconnecting the negative battery terminal for a minute or two. Once reconnected it may resolve the problems.
As the battery has died, it may no longer be good enough. Most Mercedes require a good battery for things to work correctly.
As pointed out by LK, the N 10 rely is the large one.
The problem could also be with the ignition switch as the contacts on that can burn out too.
