R129 SL500 M119 Ignition problems
dbanbery
Huddersfield
1995 R129 SL500
a re-occurring issue i am sure with the community of people running the M119 with twin distibutor/rotor setup i am sure.
as some may know i have had my car about 2-3 years and have only recently gotten round to doing the distributor caps.
i had a massive paranoia over a year ago when i hadnt run the car for ages, started it up, took it down the road and it ran terribly, stalled, and then wouldnt restart. this was traced back to moisture in the distributor caps which were cleaned out and bingo! no more problems.
on investigating this, i found that the set of caps were not matching. there was one bosch cap and one beru, with a bremi rotor and a bosh rotor. the beru cap was in considerably worse condition than the bosch one, but cleaned up and worked okay for another year. whenever the car had been laid up i would check them, or if i was going on a long motorway drive, let it run badly when it got warm and then it would work itself out of it eventually.
About a month or two ago i was travelling back from shrewsbury [about 100 mile journey and it started to randomly miss a little more than normal [the odd actual jerky thud under throttle]. it always missed ever so slightly when warm [slight dip in tickover], and i put that down to the EGR sensor and/or the old caps.
i took the plunge and bought a set of brand new bosch items for both the caps and the rotors, which i managed to get for a good price imported from germany. when i fitted these i did two things, one - i re-routed the igniton leads as they were a total mess, and two - accidentally refitted the old bosch cap i had on the other side of the engine and nearly threw the new one away! [facepalm] the car started and ran fine on the old cap from cold. when i realised my error i switched off and replace it with the new one. it started and ran clear on cold, and warmed up slightly, and when it started to warm up more, it started randomly missing, to the extent it would actually stall, and when it was test driven it was borderline undrivable. on the motorway it would work fine and then be terribly intermittent. we did 5 miles on the motorway on a test and then pulled off, and switched the second cap back over with the old one, and it worked fine, save for that slight miss on tickover that had returned. then a week later it started doing it again and i replaced the old one with the new one AGAIN and re routed the coil-cap leads. it now has its periods of hesitation but its markedly better than it was before.
oberservations.
all leads bar the cap-coil leads seem recent. the cap-coil leads are considerably stiffer than the others in places, due to age I imagine. you cannot buy these leads from mercedes, you have to buy the cable by the metre, the two different caps and the sleeves.
distributor caps and rotors are band new, the spark plugs are brand new and replaced the same time as the rotors. the old ones werent knackered, but they were 2 years old and i have fitted the correct F8DC4 bosch plugs now. it had new air filters also, and i have replaced the oil filter. [not the oil, the oil is a year old oil and still a good colour and 4000 miles into its life, [i may do it in the new year anyway] the distributor cap bowls were sealed to the cylinder heads when i replaced the caps to stop moisture getting in. everything was dry
there was a slight amount of metal dust when i cleaned it out a second time, which i thought to be remnants of having to dremel a groove in one of the old allen bolts on the old rotor arm on the one side. annoyingly enough the heads of the new bolts rounded really easily so they are stuck on. i think this might have interfered with the running of the car slightly.
no error messages. no smoke. it doesn't use oil at all.
i have deduced from all of this that what may cure the issue was to replace the coil leads,which seems to be a bit of a mission. the process of elimination is such that re-routing the leads, and the new rotors are the actions that have changed the running problems. the other running issues have gone - IE the slight hesitation on tickover... that u can see anyway. when she runs properly its more responsive, and sounds and runs perfectly, but when shes bad, its been awful at times.
i have a length of the mercedes cable, but am unwilling to dismantle the existing leads to replace the cable only. the other option is to buy the replacement components to make the leads, but i dont have the pliers to do it, and they are £135 from mercedes!
so what do people suggest? the only other thing is replacement of the engine wiring loom, which could be expensive. this is a 1995 car, so some of the wires could be brittle. is the special set of pliers actually special? or can i buy a set of typical pliers for £20 instead of £135?
Wait till some others see the thread, many now grease the caps with a silicon grease and good results had.
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
This was something else i was planning on doing too. just a spray of silicone in the caps themselves to keep out moisture..?
Yes and both sides of the rotor arms
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
You can buy third party leads from GSF - I fitted some to mine and they seem fine so far.
http://www.gsfcarparts.com/926me0270
Time it right and you'll get a 35% discount as well (most weekends it seems).
Hmm, what quality are these? i think i have a receipt for some leads
found it, all 10 replaced in 2012. cost £400:shock:
Seem OK so far - I'll let you know after we've been to France and back next week if they cause any issues!
star
Reading
Smart + others :)
The lead hardly faills, it's one of the ends that normally fail, cap or plug end. I would find out which one and replace that rather then fitting a cheap set.
When a plug lead has gone partially open circuit or shall we say a break, it will alter the timing on the plug it is feeding. This is because there will be a spark gap in that lead and retard that plugs firing.
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
The resistors in the plug leads fail open circuit. Check out each plug lead with a multimeter for resistance, any lead with high resistance or open circuit needs to be replaced.
rayhennig
1991 300CE-24 Sportline
In the OP's shoes, I'd be tempted to replace all leads so that the entire HT is in the best possible state. That engine deserves the best (although so does my M104.980!!!).
I, too, baulked at the expense and/or hard work of sourcing the leads at MB so I bought a set of Beru leads. They've been fine for at least 5 years. I regularly change spark plugs (Bosch/Beru/NGK non-resistor) and at the same time clean and silicon spray the leads and caps. Also the OUTSIDE ONLY of the distributor cap.
These are the ones, I think, that I got:
http://www.mister-auto.co.uk/en/ignition-cable-kit/beru-0300890597_g685_a0110300890597.html
Doubtless Beru does the same type for your car.
My cap and rotor are both MB.
Just my 2c worth and good luck.
RayH
Richard Moakes
CL500; ML500
Agreed, and I bought a set of leads very cheap with one missing :confused:
I bought some Mercedes genuine cable, crimp ends and a spark plug boot and made up my own lead for the missing one. Didn't buy the expensive pliers though, I used some pliers designed for crimping radio cables which worked good enough :D
RayH
Some guy on the internet
A few.
Just curious, do you sometimes think "Why do I bother?"
You can get Beru caps at present from GSF and they're doing a 35% discount weekend. Brings a pair of caps under £100.
Code is OCT35 (mods delete if this isn't allowed).
davidsl500
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
Richard Moakes
CL500; ML500
i have brand new bosch caps, so no problems there. i also have brand new bosch arms too.
ive got 2 metres of the cable and as such i'll buy the ends and a crimping tool - but the radio cable crimping tool seems a better shout that £135! i might be able to borrow one actually.
i got my bosch caps from here:
http://www.ebay.co.uk/itm/2x-BOSCH-...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Go careful with the brass end pieces, buy a couple of extra ones, they crack easily without the right tool. I got a nice crimp with a hex coax crimp tool in the end, but had to judge the tension just right so they didn't crack.
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #18
am i right in thinking that the brass end pieces screw into the plugs?
i remember one of the wire ends on the spark side being very loose when i did the plugs a few years ago, and i had to screw the plug end back onto the wire.
this is good news.
