atlantimd
- Nov 21, 2012
- Location
- Ireland
- mercedes benz E220 cdi estate W211 facelift 2008. Mercedes SL320 R129 1996.
Hi I have an Sl320 with 120k and good service history from MB dealers. The car is parked up a lot and used about 3 months a year. Last summer I noticed that driving slow the car would change to second but if left freewheeling engine Revs would not engage to move car unless given a good bit of acceleration then the car would lunge froward.
Second issue is when car is warmed up “ Cat up to temperature “ It goes over 4000rpm before changing from 3rd to 4th and then the charge from 4th to 5th is about 1 second later. I have checked fluid level it’s ok fluid is red but no history of a change.
I will be getting ATF flush done in the next few weeks and have got a filter and pilot bush.
Does this sound like a cable adjustment issue or vacuum ( it’s a 5 speed box) or valve issue.
I want to get to the bottom of it so car is ready for summer.
Also I am bit confused about getting codes from the ecu looks like my car is in that era between obd1 flash and obd2 reader, mercedes pre priority version.
