R129 Wiper "Clunking"
tiswas
1999 280 SL
Wiper works fine but then on a far too regular basis it will start making one hell of a clunk as it moves back to the horizontal starting position. It really makes a very loud clunk on every sweep back as if it is throwing itself back in to position. Next time it will work fine for a while and then start doing it again.
Doesnt really seem dependent on the level of rain coming down so puzzled as to where I start?
Thanks and regards to all.
Rob
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
Is the blade catching the frame, only ask as I put a blade on the wrong way and had this problem..
You can lift the cover off the arm and check inside, might need a bit of a clean or grease.. easy job…
T
tiswas
1999 280 SL
thanks, I will check it out.
