R170 320 slk 2003 key problem
Mike woodall
R170 320 slk
changed battery in flip key. Opens and closes doors electronically.
engine fires at position3 but dies on return to position 2
Uncle Benz
West Sussex
Mainly Mercedes
Did all this start when you opened the key to replace the battery?
M
Mike woodall
R170 320 slk
Also opened key .was going to change casing .
Uncle Benz
West Sussex
Mainly Mercedes
There is a chip within the key that is read by a coil around the ignition switch. If the chip is absent, or the wrong one, you get exactly what you have going on now. It can fall out if you fully dismantle the key body. It’s a small black device, about 5mm x 3mm
M
Mike woodall
R170 320 slk
Can I buy the chip or replacement key ?
www.ckinsurance.co.uk
