R171 rear lights units
ionod55555
Are the rear light units on an R171 200 kompressor LED or lamps because I have a rear brake light malfunction, but the lights all appear to work.
I can only find two bulbs in the back of the unit, indicator and reverse lamp?
Help please.
My CLC is far less troublesome..
Clean the bulbs up, probably a slight resistance in the connection that’s triggering the warning.
LED in the 3rd light, normal bulbs in rest
mioba
Nottingham and Köln
whip the unit out / bulb holders and have a look. You will have to anyway to resolve the issue.
Take the bulbs out, make sure the contacts are clean/good and reinsert. Make sure the bulb glass is clean when reinserting. Bayonet bulbs do wear down on the contacts.
MB bulbs last forever. I have only replaced headlamp bulbs on my W220 (once in 18 years) and a brake lamp bulb in my W251 (12 years).
John77
E200 Estate 2011, 2009 SLK 200
EmilysDad
Bury Lancs
ML350
is the car now using another pair of lamps due to one of the normal brakes lights having failed? That's what my R Class would do ... the message was along the lines of 'back up lights in use' (back up as in stand-by ... not reverse)
