R230 Boot soft close
OLLIECAT
FLINTSHIRE
SL350 08
Hi, Having the usual boot soft close issue Watched all the videos and tried the epoxy route, put soapy water on all the mechanism and no sign of a leak or sound of air. have checked at PSE pump for leaks found nothing unusual and everything else works ok. also pump seems to do things as it should with no long timeout running on. I,m now at point of it either being a fault on pse or latch mechanism. Was wondering if I could swop a line from PSE to lock mechanism to test the latch possibly from IVZ on pump into the HECK port which I believe retains positive pressure as well. Thanks for any replies.
