- Mar 25, 2010
- Location
- Tonbridge
- W221 S65 AMG - W204 C63 AMG + Various other MB's
- Moderator
- #41
As far I am aware AGM vs Flooded.
An AGM can take a higher charge rate and requires a slightly lower FLOAT voltage (end of charge) than flooded. (2.21-2.25 volts per cell vs 2.3 ish volts per cell).
However, you wont be able to get 15.7 volts during the bulk or absorption charge phase with a 5 amp charger on a 100ah + AGM battery so don't worry. You would need a 30+ amp charger to do that.
Also, the Ctek wont float charge any battery to 15.7 volts, it only uses high pulses of 15+ to waken "dead" batteries.
