Hi all,
I'm a new member seeking some help/advice:-
The passenger side door mirror generally folds out beyond the correct position, sometimes to the correct position.
Any solution suggestions?
Does the unit need dismantling for correction? If so, how do I remove the assembly from the car? (I have gone so far as removing the mirror glass, glass adjustment motor and the outer cover).How do I compress the large internal spring?
