R230 Dual Battery On-board Electrical System
s5tuart
2003 R230 SL350
So, does the consumer battery help the starter battery if the starter battery is low?
SL63 Mark
The South
R231 SL63 AMG
The consumer battery always goes flat first, as it has all the current drains on it. The starter battery never gets low, as long as it is good condition, as there is no drain on it.
So in 10 years of ownership my starter battery never lost charge, or failed to start the car. I did replace it as a precaution when it was 15 years old.
+1 on charging on rear only.
My understanding is that you only need to charge the rear battery, because it's connected to the front in some way and will maintain that also.
+2
Friend kept his R230 500 rear battery on a conditioner, very rarely used it, but never had any starting issues (or consumer offline warnings)
Miltomatic
R230 2002 SL500
Good morning.
After some trouble with my 2002 R230 SL500 the local auto-electrician has told me I need a new Battery Control Unit. I think the part number is A 230 540 0945. Apparently these are unavailable from MB - can anyone recommend a good source for a replacement or someone who offers a good repair service?
Thank you
Milt
00slk
Cambridgeshire UK
Good morning.
Thank you
Milt
LG Motor Services in Swaffham are breaking an r230. Also Giles is ex Mercedes technician.
Miltomatic
R230 2002 SL500
Good morning.
Thank you
Milt
Incidentally, are parts A 230 540 0945 and R230 540 1045 the same and inter-changeable? I suspect they aren't. Should I be wary of someone who says they are?
Thank you
Milt
Don't tell Giles I recommended him, he'll put the price up :D
Peter
Thank you. I think the price will probably be stiff enough.
00slk
Cambridgeshire UK
Thank you
Milt
All parts have different part numbers for a reason, although some can be used as they are interchangeable. I have used 3 different part numbered products on the same car without issue.
I'm sure one of the parts or specialists on here can give you a better idea.
Conor
London, UK
If you need an electronics repair you could try Autotronics.
Thank you
Milt
1045 will be the updated version of 0945 and is very likely a direct replacement.
Miltomatic
R230 2002 SL500
Thank you, that's good to know. I believe I have found one - should be here on Tuesday.
Do anyone have experience or recommendations for the reconditioning these units. It would seem to be sensible to get the original repaired in case this happens again. They aren't going to get any easier to find.
Milt
Miltomatic
R230 2002 SL500
Thank you, I will bear Autronics in mind.
milt
