R230 Fuel Tank Baffle Repair
Conor
London, UK
Sounds like the baffle has broken away from both welds, top and bottom :( that could be a right pain.
Yeap. Need to get a look in.
00slk
Cambridgeshire UK
Those inspection cameras are worth their weight in gold ;)
Conor
London, UK
Yea, I agree. Good tool kit to have. I've kind of resisted up to now. I did have a cheapo Bosch one from Amazon but returned it as it wasn't great.
I think at some point i'll invest in a decent unit. I wonder which one is good.. Perhaps tool time Tim @Chrishazle might have some input.. For some reason I have you down as the authority on tools here, Chris :)
00slk
Cambridgeshire UK
I have a cheapo one I got from lidl, had it now over 6 years and have used it quite a bit, especially good for checking cavities in teeth :D
Conor
London, UK
Oh I must check that. Was curious what it would be like? Assume it's good.
I’ve the same one, you obviously didn’t read the manual... specifically advises against using it in body cavities...:rolleyes:
00slk
Cambridgeshire UK
For what we paid it's not too bad and has worked for me every time I've needed to find something in awkward places :) The picture focus is quite reasonable but if you magnify it fully and try accessing narrow space it can be a little challenging ;)
Summed up it'll do me :)
00slk
Cambridgeshire UK
You party pooper Russ.......Not been to some of the parties then? :p
Conor
London, UK
There is a slight chance you might be talking about different parties.. @00slk why don't you elaborate on the party you are referring to, in order to avoid confusion :) :p
SL63 Mark
SL63 Mark
The South
R231 SL63 AMG
  • #51
OK folks I've got some good news on this. I decided to have a go at fixing my banging fuel baffle, I read all the how to guides on the internet, how hard can it be I thought.
So after a few weeks thinking about it, I didn't like the spring idea, too uncontrolled, and possibility of sparks and corrosion, so I thought, what would work well in a fuel tank, ah yes, copper wire. I have a roll of 1.5mm copper wire I have left over from another project. So I used up as much petrol as possible, took the car outside, got my fire extinguishers handy, disconnected both batteries (the last thing you want is a spark), removed all the boot lining and exposed the tank. I removed the sender and peered inside, but I could barely see the loose baffle. How the hay do I get a copper wire round that ? So I made a loop in the wire, and made a double hook in a coat hanger, looped the wire round the gap in the baffle (see photo) and pulled the wire through. Fortunately copper is very ductile and malleable and easy to work with, it also cannot cause sparks or corrode (much) so in theory it is the perfect material (it seems to me). Once I had the copper wire round the baffle I pulled it tight (not too tight mind you) and tied it round the sender taking great care to avoid the electrical contacts, otherwise the fuel gauge will not work. Replacing it all is pretty fiddly, but I did it, and hey presto, no more bonging.
Hope this is of help to someone.
Conor
London, UK
It's fantastic! I'll be back to this thread (...aaand all the others) later this year.
dave140
Registered
350SL 2005 3.7
Thought id share a picture of another successful fix i did yesterday on a forum members car.
Hi Raj. Are you still offering to repair the fuel tank baffles? if you are, can you let me know how much and how long it takes please? I live in Walsall so easy to travel to you. Thanks.
norman whiting
SL 350 2004
Hi Raj
-raj-
Coventry
Multiple R230's & E250 CDI
Hi Norman, Sure i will message you.
