noonboots
- Mar 17, 2018
- R230 SL 500 2003 M113 5.0l
Is it possible to check these drain holes are clear without stripping the interior, eg at the oulet wherever it may be.? I'm thinking it may be possible to prevent future problems caused by blockage.Window will definitely hold the roof off. The window position might come via the door control module, but the roof control relies on a message verifying window position before it will open. I fixed one a couple of months ago where the nearside rear window regulator was completely submerged. I cleared the drain and replaced the regulator and it was fixed. I accept that its not definitely the same problem, but based on the description it sounds similar.
