There is a lot of weight with the vario roof, I’d be lubing the mechanism and replacing the strutsDo they all have the soft close boot?
If they have mine doesn't work. Also the boot lid seems incredibly heavy to lift up. Perhaps I need some new struts?
WDB2304672F048681
Could be wrong but I thought all had this feature. If it's not working there's a leak somewhere which appears to be fairly common. Plastic locking mech sometimes leaks but can be repaired. If central locking etc still works I would say there's your problem. Fortunately the struts are fairly cheap (in MB parts terms) and easy to replace.Do they all have the soft close boot?
WDB2304672F048681
Yes indeed. I have a pair on order and I think even I can do the work myselfI don’t know if the 350 has a soft close boot but I had a similar experience on the 500, which resolved by replacing the struts. As mentioned before, straightforward and one of the cheaper fixes…
Hoping it does the trick.Yes indeed. I have a pair on order and I think even I can do the work myself
I'm really hoping I don't have to fix the soft close thing though![]()
I think I've seen a YT video where they were replaced by LED ones with no canbus errorHoping it does the trick.
Also something that you may have already done, but check the reversing light bulb covers for any cracks… whilst you’re there. You can get ingress which can lead to all sorts of trouble.
Yikes! Good tip I will only do them one at a time but I have a golf bat I found and can use that to wedge itWhen changing the struts be handy to have someone take the weight of boot , I was changing a strut ( not mb ) and one popped off and boot lid fell and the strut had shot to one side so badly damaged the edge of boot.
You make the thread, I nail it into the right section… not with “no more nails” though, as that’s not waterproof…
I recommend wood, It’s always good to have stout wood when strutting…Yikes! Good tip I will only do them one at a time but I have a golf bat I found and can use that to wedge it
That's what I used when I did mine.I recommend wood, It’s always good to have stout wood when strutting…
Neither are R230s so it's perfect.You make the thread, I nail it into the right section… not with “no more nails” though, as that’s not waterproof…![]()
DoneYou make the thread, I nail it into the right section… not with “no more nails” though, as that’s not waterproof…![]()
