R230 strange noise from rear boot area
lovemerc
South Wales
ML250 GLE AMG Sport. Previously - SL500 R230 2003 & S430L W220 1999.
In isolation from a suspect pump problem located in the boot, my SL has an odd noise that sounds like a knocking but is intermittent during a drive. It comes from the same area but is hard to pinpoint.
It seems to happen more, when I reverse and stop quickly. But it also happens when coming to a stop or going slow, there just doesn't seem to be a clear pattern.
Any advice would be appreciated so I can check...
Mark.
A loose baffle in the fuel tank is well known but only after Dec 02 I believe
L
lovemerc
South Wales
Thanks Malcolm - can I access myself as a layperson?
Also, thanks for your reply on the PSE, I assume this is not conntected so posted it here. Would you know if that 20A fuse is blowing, that it points to a replacement of the PSE or should I find the short causing the fusing?
If the 20 amp fuse has blown, then the PSE pump is U/S
scotty2hotty81
If it is the baffle in the tank it will get more apparent as the fuel level gets lower, major job to replace I'm afraid.
L
lovemerc
South Wales
Thank you both, I appreciate the help.
Malcolm, can you remind me, does the PSE operate with the Vario roof as I'm getting that message about the boot separator?
Mark.
Gkinghorn
Bournemouth
E350 CDI Cabriolet - 2011
There are various 'home' remedies to it including the one where the guy used the broom handle to more or less smash it down... There is thread n here somewhere abut it all.. Will see if I can find it or someone else will...
Mark.
Yes if the roof does not know where the boot id is it cannot work
L
lovemerc
South Wales
Thanks Malcolm.
If the pump is faulty I still have a nearly new one going
Monday
Surrey
SL500 2020, CLA250e 2024
Another source of R230 noises
Just one other place to look. I had the boot lid LED stoplight replaced which involved stripping out the boot lid liner. Following this there was a random rattle from the rear of the car. The fact work had been done helped to pinpoint it but still took the dealer 5 hours to find (or so they said but they didn't charge me for it). I gather the work involved a "very small technician in the boot with a torch" and some "special MB foam padding".
tode
NW FRANCE
E300e 2024
Just make sure it's not something silly like the tools moving it the spare wheel well . . . ;)
drmw
Yorkshire
www.autonomed.co.uk
or indeed the boot separator - sure someone posted on here that he eventually found that was the source of an annoying noise
L
lovemerc
South Wales
All,
Thank you so very much for these thoughts and replies, it's very much appreciated.
Mark.
maximan
glos
clk 230 KOMP, MGB GT `73, FZR 1000 Genesis, Honda C90.
Sounds like it could be a broken rear coil spring.......but hey what do i know :D
Maximan
Gkinghorn
Bournemouth
Hopefully he got it fixed between October and now though :D
maximan
glos
Yeah your right, was a little late but just scanning and i thought maybe i could help.
Maximan
