SL63 Mark
- Oct 1, 2012
- Location
- The South
- R231 SL63 AMG
An "Auxiliary Battery Malfunction" message came up on the dash on my SL, on Christmas Day, a nice Christmas present, as I was on my way to the in-laws for Christmas dinner.
Anyway I parked the car, hopped in the Landie and forgot all about it.
Last night I did a bit of reading on the internet, and it turns out this is a common problem, The small 12V 12 Ah auxiliary battery lasts about 7 years, so mine was due for replacement, as the car is seven years old.
The battery sits behind the drivers seat (UK car). I took some photos as I went, so I thought I would share them, and the steps for replacing the battery. Most of the internet write-ups say it is impossible to remove the battery without cutting the lugs on the battery cage. I found this is not necessary if you unclip the trim covering the rear section of the centre console.
The first step is to remove the two trim pieces on the shelf behind the driver. You can see where the clips are in the photo below.
Now you can see the battery cage revealed. First remove the 8 T30 Torx screws.
