The car only has air on the back.
Passenger side rear was down after about 24 hours when not driven. Drivers side down a bit, but assumed this mainly due to the other side dropping.
The Air Bag on one side didn't look too good so put a new one on.
Started the car, it went up (as it always did do) - used Star to do automatic levelling - but was not level, about an inch lower on the side with the new bag on.
24 hours later passenger side rear is back down again - so problem same as before.
Have sprayed water on the 3 port valve in the engine bay - can't see an obvious leak, are there any other obvious points where the pipe might fail, is one other possibility the 3 port valve block could be leaking internally perhaps....
When I plugged in star a second time, the error was 5501 and suggested checking for air leaks...
Any advice would be most helpful...
