Radiator fan on the A140
Mark weaver
Plymouth
Hi all
I am having a few problems with my radiator fan, it is not coming on.
I have changed the temp sensor and the relay.
I have changed the ELECTRIC COOLING FAN MODULE too but it is a 2004 module and my car is the 2000 modal. Do you think that will make a difference ?
is there any thing else i can do or have to do.
Cheers
Mark
Cole@MBS
www.mbssouthampton.co.uk
There could be a difference but i don't believe so! the fan is controlled by the engine ecu, could be a idea to get it put on a diagnostic and see if theres any fault codes in there!!
Cole@MBS
that's weird then!! if you get a open circuit on the cooling fan it will put a fault code in off,"open circuit to suction fan" so i wouldn't think you have a wiring fault!!! maybe the fan modules are different, if you can wait untill the morning i can check on epc for you!!
Cole@MBS
Will need your chassis number then Mark!!
Cole@MBS
Is there any chance you can see the part number of the fan control unit Mark, if so, put that up, not a prob if you cant!
Cole@MBS
sorry mate, just got in, the number it should be is 1685000193 price of £99.50
M
Mark weaver
Plymouth
That is cheaper than the mercedes garage down here.
Is there any chance i can buy it off you and give you the money for delivery too ?
thanks
Mark
Cole@MBS
Going back to this thread now Mark after the pm,s, no i dont!! i would have to see the car! you have, 1, a wiring fault from the ecu to the fan control module, 2, you have bought a bad control unit! would need to have it on a star machine to see what actual vaules the engine ecu are showing!!
