Romel
- Mar 29, 2022
- E220 CDI W211 170 HP Y2007
Hi friends,
I have Mercedes E220 CDI W211, year 2007, phase II with 170 hp engine
My fan runs at full speed when ignition on (engine off)
All wires, coolant temperature sensor, AC pressure switch, fuses and relays are ok
The PWM signal from ECU to the fan controller is 2.24 V (green/blue wire); is this voltage ok ? I know it should be lower but I need the exact value
I also need to know from which component comes the green blue wire (see attached photo) pluged in B1 on the Driver SAM
Your help is really appreciated friends
Nice day
Nice day
