I have a 2012 W204 C200 CDI that’s fitted with the Radiator Shutter (equipment option 2UI). The shutter never closes, even when it below zero degrees outside. Does anyone have any ideas on what the problem might be?
Hi,Are those shutters, related to transmission cooling?
Never had them myself but, placed at the front of the car and moveable, they must have every bit of crap possible thrown at them, I assume they must be hinged or swivel in some way? I'd be giving them a good clean first.I cannot believe that I’m the only person that has a problem with the shutter and I was hoping that someone could suggest a “home” fix, such as a fuse.
My W213 had them, I only had it for 18 months from new, so no issues with them. Also had them in a 5 series BM (shudder…)Never had them myself but, placed at the front of the car and moveable, they must have every bit of crap possible thrown at them, I assume they must be hinged or swivel in some way? I'd be giving them a good clean first.
That looks like the same info that was banded around for the Airpanel. That is active external shutters, which is different to active grill shutters that sit between the grill and the rads.Hi,
No, it’s in front of the radiator and is there to aid warm up of the engine, speed up cabin heat and reduce fuel consumption.
The engine control unit adjusts the shutter. The car radiator shutters will open when the vehicle reaches a speed above 180 km/h, the cooling water temperature reaches above 34 °C, suction fan performance requirements are above 30 % and the coolant temperature goes above 105 °C. The shutter remains closed when the engine is switched of or until these conditions are reached.
