Radio Fuse Blown?
Maggra
need to know where in the car the fuse is, have wiring info and know its 15R - 5 amp rating, off fuse block A? where the hell is it? have a CLK 230 coupe on a V plate - 2000, W208 with no music!! help thanks
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Welcome to the forum good to have someone else from Southampton on the forum.
The fuse box for the radio i believe is the same as the 202 and is under the bonnet by the brake fluid reservoir.
M
Maggra
great, thanks for giving me at least some where else to look - got an 2006 copy of the Merc workshop WIS and have spent a couple of hrs sorting the wiring diagrams but just can't get the its location sorted - takes such a long time to find the right sub directory for the cars mech' layout the software crashes, check out the block in the boot and drivers door/dash so have lots more to find as only had the CLK for 3 weeks - Thanks again
M
Maggra
Also noticed that the MERC ISO Power connections are not standard, had a problem with making the ignition feed to my new DVD player! the main battery feeds are Ok but it looks like I'll have sort out the ignition feed issue once I get power again, cheers
PS how do you get the pic of your MERC along with replies?
Dont forget that WIS is LHD so the fuse boxes are on the opposite side.
You need 30 post to be able to get an avatar up with your post
You can use the cigar lighter for a switched live feed
M
Maggra
Power is now sorted, blew the rates out of a 15amp fuse! I'll do the cigar lighter for my switched feed once I can figuare out how to get to it? got the ash tray out but no further but have now got to leave to take the wife out xmas shopping so wont be able to sort until tomorrow - thanks again guys - merry xmas
