radio interference
mrtidy
south manchester
When i put my heated rear window on i get bad interference on my radio,any help from anyone?its a CD special(becker) standard fit in my 1998 W210 E200,the radio works great and nothing else interferes with it,also does anyone know where the aerial is?i wondered if it come loose or something but i havent a clue where it is.....thanks in advance.
The aerial is in the back glass window,
One method to try is to put 13.8-14 volts through window wires for 20 mins.
two, fit supressor cap to window
three, New window
Malcolm
Malcolm, Why would this help? :???:
This is an MB cure,, , under the higher voltage the offending bad wiring in the glass will weld itself to stop the crackling, another way is to put a Capacitor of about 20,000Mfd across the connections and this acts as a giant suppressor
dave.robbo
Gloucester
2004 SLK 350 R171
Thanks for that. Gotta be worth a try on mine, then, I guess!!
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Is,nt there a suppressor already fitted to the rear window heater? It could be this is U/S I think it is mounted on the drivers side of the window behind the "C" piller trim i,ll try and find it on the EPC.
That is the 20,000mfd cap that I mentioned above and not all cars have them
bigasotonuk
Southampton UK
Hi Malc,
I thought it was fitted to all the MBs with the aerial element built in the rear window, have just tried to find it on the EPC for my AMG and can,t find it. So it being not fitted to all MB's explains this.
Hi Malc,
Hi Andy,,I did loads of post on this a few years back, I could never work out what car had them and what car did not. these started back in the 126 days, they were fitted in one side of the C pillar
