Rattle Noise??????
rajinder_1
Midlands
Hi Guys,
DOnt know where this rattle is coming from... i only hear in quiet small built up streets. The car is 2001 sl320 M112 engine.
It seems to happen at the low rev range as well. Thought that it may be the cat but have had car on ramp and tapped the cats to see if i can hear the rattle but nothing.....
any ideas as it really bugs me when i drop the window and hear it?????
Raj
R
rajinder_1
Midlands
Hi Parrot,
You are right it is from front of my left hand side looking at the engine, i heard it this morning, usually i only hear when i drive the car on lowish revs but for whatever resaon it was audiable this morning.
I know for certain its not the cats as it dont do it all the time.
Do you know what it could be parrot?
Raj
One of the heat baffles, they do come loose.I mean it is a baffling fault ;)
Malcolm
R
rajinder_1
Midlands
Baffles
Malcolm
Mmmmmm Sounds about right, will need to investigate thanks malcolm
Raj
Indefatigable
Rattle Noise
This might not be of any help but i recently had a very regular tap.tap .tap on my 300TE.Not unlike the ticking tappets when cold.
But this was not the case,on watching the fan belt i cold see that the tick/tap was at belt speed.
On closer inspection what looked like a perfectly good belt had a small section missing on the inside,this was making the noise as it passed over just one of the pullys on the engine.
New belt ,no noise.
This is most probably nothing to do with your noise but you never know.
Richard:idea:
BarryG
Sunderland
Once again may not be much help I had similar noise only heard in enclosed spaces whilst driving slowly. Turned out to be an underinflated tyre :)
Barry, how much did little bow peep get, :rolleyes:
Malcolm
BarryG
Sunderland
Malcolm
Actual figure was undisclosed but parcels of lamb chops appear on her doorstep regularly.:p
R
rajinder_1
Midlands
guys,
i went to kwick fit, the guy there said that the noise seems to be from the rear part of the exhaust, as malcolm had pointed out earlier......
can anything besides replacing it rectify this or will i need to put new one on?
Raj
guys,
Raj
No easy fix Raj, you can never shut them up,short of replacement. I have senn guys poke sticks and all sorts up the pipes, but it only makes it worse.
Malcolm
R
rajinder_1
Midlands
is it best to look at aftermarket, or oem for this part, its not that bad, i can notice it but its not very noticable to the average joe.....
raj
I think for a perfect fit you have to go OE, I do not know of anyone that makes a good box for the 129067 car.
Stand the car up on end,on the front bumper and tip some fast setting resin down the exhaust pipe:D ,maybe not.
Malcolm
R
rajinder_1
Midlands
This rattle will be the death of me, i heard it the other day and i lifted the bonnet it sounded like it was coming from the inlet manifold, was quite distictive, i recorded it on my phone will try and add on here if i get it on you will be able to hear the disinct tinny sound...
raj
R
rajinder_1
Midlands
sound.
i got the file on my pc it wont let me attach to the forum, its a quicktime file gp3 i think....
Parrot of Doom
Manchester
Change the extension of the file to a .txt
That way people should be able to save it to their desktop and rename it. The correct extension should be .3gp and Quicktime will play those.
My damm computer will not play anything other than the media player.
wont even open Abdobe 8 PDF reader, they are all activated, dont know what to do. its the same on Fire fox or explorer 7
Malcolm
R
rajinder_1
Midlands
  • #18
ok i will try again tonight to attach to the forum, malc if you go to www.downloads.com and in search type quicktime its a free download and will enable you to play the file i sent to you.
Raj
Pipemaster
East Midlands
SL350 R230 / 2006 / 3500
Try file associations
Malcolm
Hi Malcolm, it's probable that your PC is set to associate all your media files to the Windows media player if you dont get a pop up box asking you what to do when you click on a certain file format. This is a windows environment issue not a browser issue. What type of Windows are your running?
below is the procedure in XP
How to change file associations
You may want to change the association of a file name extension from one program to another. For example, you may prefer to open text files (.txt) in your favorite word processor so that you can format the text. By default, text files are associated with Microsoft Notepad. By default, file name extensions for known file types are hidden.
To See All File Extensions
1. On the Tools menu in My Computer or Windows Explorer, click Folder Options.
2. Click the View tab.
3. Clear the Hide extensions for known file types check box.
To change file associations
1. Right-click a file with the extension whose association you want to change, and then click Open With.
2. In the Open With dialog box, click the program where you want the file to open, or click Browse to locate the program that you want.
3. Select the Always use the selected program to open this kind of file check box.
How to create file associations for unassociated file types
You may want to create a file association for a file type that is not associated with a program in your computer. There are two common reasons for this action:
• A program such as a database produces file reports with extensions that are not registered in Windows XP.
• You receive e-mail message attachments that are created in a program that is not installed on your computer, but there is an installed program that can read these files.
To create file association: 1. Right-click a file with the extension that you want to change, and then click Open, or double-click the file.
2. Windows XP displays a dialog box that indicates that no program is associated with this file. The dialog box offers two choices for creating an association:
• Use the Web service to find the appropriate program
• Select the program from a list
Unless you want to find and download software that opens this file type, the best choice is to select the program from a list.
3. Windows displays a dialog box that displays programs that are installed on the computer. If the program that you want to use for this file type is not listed, click Browse to locate the appropriate software. Select the Always use the selected program to open this kind of file check box.
Hope this helps
Thank you Seve, I will print it off and give it a whirl.
Malcolm
