It does sound like a power steering problem, but could you explain the rattle a little betterMy c200 99 t-reg, manual, rattles when on full lock and pulling away, it sounds like the engine is going to cut out and when the revs pick up the noise stops, any one experienced this before?
i think i'll stick to computers
No Malcom, Im not saying the steering pump rattles, but pressure on full lock can cause rattles. and the tensioner is only one of several that can rattle. AC compressor is another, idler wheels another, ABC another steering pump another. The list is endless.All input is vital as you know Niall, its just that power steering pumps don't really rattle, I know that eric says that they do, but thats only in China.
Malcolm
Lol, ok malc, got thee message.Eric I am not going to argue all through this post, power steering has relief valves when on full lock,and a power steering pump that rattles ?. I have yet to know of a rattling compressor pump and this car does not have ABC.
Look you want the postings as complicated as possible, I like to keep them simple with things that fail on a regular basis.
Thank goodness I do not get rattled easily.
Malcolm
Malcolm
My one does this too, never bothered me too much It now has character
Thing to do is to watch the components when the steering is held on full lock.
The damper is easy to disconnect and checked to see if there is any damping left
Thanks Malcolm, ill try to look at this as soon as possible and post back. Ive just come in from changing the rear brake pads and found the nearside caliper was seized and the metal pipe feeding this caliper has corroded through were it is held to the body with the rubber type clips! Lucky i spotted the flexi hose was wet and traced it back, looks like a pain to change.
So sorry to hear that, is it allowable to have correct joins in brake pipe, I mean that the flexible is a join. Brake pipe flaring tools are quite cheap, if the rest is OK. I can check for you with my MOT man
