RE: New brake pads – rumble & vibration
Andy Campbell
Scotland PH2
W169 A170 petrol - 2005
Greetings
Recently had new brake pads fitted to the rear brakes and there is a concerning rumble and some vibration.
The brakes (new pads) are fairly recent and have done about 200 miles since
The noise / vibration did go away on a 60 mile drive but has come back
Any input ?
grober
Scotland
W204 C200cdi estate
Possibly the wrong pads fitted? There were many versions of the rear callipers fitted to these cars over the years and its important to fit the correct ones for the chassis. May not be the brakes "per se " but something was damaged when the pads were changed or something that just happened by chance around the same time. IF ITS BRAKE RELATED you should experience a notable change in symptoms when applying the brakes gently while driving as any excess slack or movement may be taken up.
A
Andy Campbell
Scotland PH2
RE: Brakes - noise
Hi grober,
Thanks for your response.
Just to clarify (sorry) - there is no vibration / noise whilst driving – this only happens (noise / vibration) when I apply the brakes.
Cheers mate
grober
Scotland
W204 C200cdi estate
May be a reflection of the state of the rotors then-- the previous pads will have " worn in" to match any surface imperfections/scoring/rust on the disc. The new ones won't--- they will eventually "wear to shape" and become quieter but possible indication the rear discs are warped or heavily scored?? If the discs are OK then its possibly some sort of problem with the new pads?
