RE: W169 A150 – spark plugs change
AndrewCS
A Class W169 A150 manual 2006 - 55k
Greetings
I’ve had a look at changing the spark plugs on my 2006 A150 and with the angle of the engine seems not to be a straight forward (no pun intended) task.
Can anybody offer any advice for doing this job?
Also, does anyone know what time MB allows for this ?
TIA for any input
tpn
S204 OM651 2012, Daimler V8 250 X 3
Greetings
TIA for any input
Apparently you are supposed to remove the inlet manifold to do it:shock:. This guy seems to have a a way around that.
Craiglxviii
Cambs UK
The angle of the dangle, is directly proportional to the heat of the meat. Apparently.
Hope this helps :)
tpn
Hope this helps :)
provided that the maxis of the axis, and the gravity of the cavity, remain constant.
V6Matty
Newark, Nottinghamshire
It’s a PITA as you’ve found the angle is canted towards the back of the engine bay , so yep easiest way to do them is remove the air box and manifold, about three hours total to change your plugs according to Mercedes.
But as TPN found there is a slightly easier way to do these, the only issue is if it’s not perfectly square on the plug then the risk of snapping a plug in the head is greatly increased
A
AndrewCS
This video came up on the YT sidebar, I see MB have a specific HT lead removal tool and the plugs changed without intake manifold removal.
Looks like a 30-minute job
YT video - search for -
Mercedes A-Klasse W169 / Zündkerzenwechsel / Changing the Spark Plugs W245​
Any comments on this?
V6Matty
Looks like they created something specific for the job, I det the tool isn’t cheap though if you can even buy it from Mercedes’ themselves
mioba
Nottingham and Köln
Although these tools may not cheap they are often a lifesaver.
Many companies do aftermarket tools like sealy
tpn
There is usually an easier way to do these awkward jobs. Same with the inlet manifold on the 220 cdi om651.
Mercedes take out the engine to do it.
Some indies leave the engine in situ and remove the battery and firehead.
I did not remove any of those, just bought a few wobbly extensions and got there.
No great imagination needed to make a tool like that to pop of the HT leads. A bit of steel plate and an angle grinder and away you go.
