Rear brakes dust/splash plates
Floppydog
A180 cdi 2005
My W169 rear splash plates are starting to hole with corrosion , to replace these I believe I need to remove the rear hub , using a slide hammer puller . My question do they work or will I end up trying to bash them out ? And if the puller works do the bearings require replacement. I would be doing this job on the drive . Am I better of leaving for the garage . The job in its simplest sense looks easy enough but as I am finding with any job on this car that's not the case .
Droverunner
West Cambridgeshire
2007 CLK 220 CDi Sport. 2014 S-Max 2.0TDCi.
I found a crafty method online which I adapted to do Mrs D's CLK backplates without pulling the hub and it was a total success. I think I wrote it up on here, I'll look.
Droverunner
West Cambridgeshire
Here it is... post 8 onwards in this thread...
F
Floppydog
A180 cdi 2005
Hi thanks, but I am fairly sure it's not like that , the 4 bolts that hold the hub on also hold the plate on . In a massive stroke of luck that's is lol .
Craiglxviii
Cambs UK
Sure. Just cut the backplate with an angle grinder before fitting, then mig it back up and paint it afterwards. My CL500 was the same.
F
Floppydog
A180 cdi 2005
The plate sits behind the hub bolts so is on the outside, do mean weld the plate to the subfame ? . It is not possible to cut and fit as some can be done .
F
Floppydog
A180 cdi 2005
To correct myself the back plate is sandwiched between the subframe and hub , held in position by the hub nuts .
Craiglxviii
Cambs UK
No. You cut the plate itself, but equally for your car I may be talking rubbish.
Droverunner
West Cambridgeshire
Ahh OK if yours is 4 bolts to remove the wheel bearing assy as a whole that's loads easier. Brake pads, caliper and carrier off. Probably pull out the ABS sensor. Then unbolt whole assy... remove disc shield and replace. Bolt everything back.
F
Floppydog
A180 cdi 2005
Thanks , am lightly to have difficulty in removing these parts ?
Droverunner
West Cambridgeshire
Don't scare him... its all bolts, bit of easing fluid and a light tap at most.
F
Floppydog
A180 cdi 2005
I have worked on many cars for over 40 years , I have angle grinders, impact wrench etc . Just seams a bit silly to have to remove the hub really by design.
V6Matty
Newark, Nottinghamshire
When my Indy did mine last time they had a real issue getting the hub off one side, took him three hours to eventually get it all freed up with enough penetrating fluid to sink a small ship, luckily no sheared bolts otherwise that would have been another couple of hours work for them
F
Floppydog
A180 cdi 2005
Thanks , it's a simple job really , I had it stripped down yesterday to have a look , reaching the springs can be challenging . I should like to tackle the job myself however it's rather right access and it's just on the drive . I may leave to a garage on this occasion . Which is slightly annoying as if straight forward it's a hour job Really .
Thanks again
F
Floppydog
A180 cdi 2005
Should read reattaching the springs ..
