Rear dampers need replacement.
dursleyman
Dursley, Glos
2009 C220CDI Estate, 1977 Triumph TR7 FHC, 1980 Triumph TR7 DHC
On a recent cross country journey I noticed that the rear end of our W203 was getting a bit "lively".
It definitely feels like the rear left damper has gone soft so I will need to change the pair.
The car is a 2001 C200K and has done about 80,000 miles so I guess it not too surprising.
Does anyone have any advice on doing the job - for example how easy is it to get access to the top mounting?
They are quite straight forward to change,, I can see if I have a work sheet
D
dursleyman
Dursley, Glos
I would appreciate any pointers on how much trim/carpets etc I need to take out ( if any) to get at the top mount.
I will be in big trouble if there are any oily marks on the trim !
Ellsy Tanners
Mars
Do check your spring while you are at it, prone to breaking at the bottom.
Ellsy Tanners
Mars
Just the boot liner on the side,s. Shocks are recommended to be replaced in pairs dont forget.
roofless
w124 e220 estate
loads of wd40 on the bottom bolts the day before they tend to be seized to the bush
I will sort out a DIY sheet for you in the morning
