merc911
I have noticed that when I use the rear demister that there is some interference in radio reception - most likely due to the aerial being built into the rear window. My car is a 2001 W210 E200. Any comments.
If you insert a lamp in place of the window you have then moved the source of interference away from the aerial.the cap is recorded by MB as a source of interference.severn said:Most likely its the heated screen itself thats causing the problem. heres how to test.
remove both c pillar trims
disconnect heated rear screen connection at screen leaving suppressor in circuit and get a 55w headlamp bulb and connect it to the removed rear screen connections you will have to temporally extend the leads. The bulb is a resistive load and takes place of the heated rear screen.
turn on the ignition and the rear heated screen. turn on the radio if the interference has gone its the rear screen thats faulty. If not its something else.
Lay money on it being the rear screen
television said:If you insert a lamp in place of the window you have then moved the source of interference away from the aerial.the cap is recorded by MB as a source of interference.
Malcolm
severn said:The aerial is build into the rear screen? so yes disconnected the heated screen power will stop the interference if faulty. The bulb substitutes the screen and draws a similar power so tests the rest of the system.
Trust me i changed dozens of rear screens for this problem
The interference that you have, little more info please. Is it on AM or do you only have FM. what kind of interference, crackle,whine etc. Has it always been there, if it is something new and just happenedmerc911 said:I have noticed that when I use the rear demister that there is some interference in radio reception - most likely due to the aerial being built into the rear window. My car is a 2001 W210 E200. Any comments.
