Rear Heated window problem
Armani.X
Mercedes c class 220 / W204
I’m just wondering if you encounter the same problem with me, what I got at the moment is the Rear heated window not working. I’ve check the fuse and the relay all working fine and switch button and it lit up. Any help would be great. Thanks in advance.
mioba
Nottingham and Köln
Check there is no break in the window "wire" that runs across the screen, if so it can be fixed with silver paint to bridge.
Open the boot liner and see if you get voltage to the connecteor for the window wire.
A
Armani.X
I’ve just check the paint and it’s all intact!
John Laidlaw
Wirral
Land Rover Discovery 4
This might be best in the correct technical section?
www.ckinsurance.co.uk
