Armani.X
- Jan 31, 2020
- Mercedes c class 220 / W204
Hi Guys,
I’m just wondering if you encounter the same problem with me regarding with my Mercedes benz c class W204 the rear heated window is not heating up although the switch light on, the fuse and the relay working fine and I check the wire and it’s running 14. something volts but after I connect to the rear screen glass connector and check the wire on the glass it has no power at all. Something a bit odd any idea would be a great help!
