Rear indicator issue
bembo449
gainsborough , lincolnshire
Some of you will know ive had an indicator issue which i thought was down to a dodgy bulb holder in the OSF drivers head lamp but another holder did not cure the problem however i noted today that the OSR indicator bulb is slightly less bright when operating so i cleaned the contacts and tried the holder from the opposite unit , stiil the same , it looks like theres possibly earth issue with the rear unit so can someone advise where the earth is so i can test my theory
EmilysDad
Bury Lancs
ML350
... so can someone advise where the earth is so i can test my theory
The bigger brown cable on the loom ..... seems that they can have an iffy connection where it makes contact with the light unit which makes them get hot & potentially burn the contact out
Mike Smith
Reading
2019 C200 Estate AMG line plus
The same issue also plagues BMW's
The earth wire burns out at the plug.
The normal fix is buy a new one from Mercedes but the best fix is to make the earth directly to the earth track on the bulb holder.
