Rear Rattle: Likely cause could be the parking brake. Affects R230 and others.
sausage
SL
Hopefully this will help someone else.
I recently bought a R230 and after a short while realised that there was a very annoying rattle at the rear. MB looked at the car, and could not find anything wrong.
Searching the internet for a rattle on an R230 leads to lots of discussion about the fuel tank - it seems pretty easy to test this, "does it sound the same with a full tank vs a near empty tank"? If not, then I suspect there is a reasonable chance it is not the cause. Further still, the MB service manger said that the issue with the baffles coming loose in the fuel tank creates a sound that is more of a "thud than a rattle".
I later watched a youtube video showing how the retaining spring in the rear park brake assembly on an MB can fail and cause a rear rattle.
So, the next time I was out in the car driving over a bumpy road that caused the rattle, I deployed the parking brake one click, and the rattle stopped. I tried a few times, each time with the same results. That to me seems a very strong indicator that the rattle is being caused by the parking brake assembly. I wish the MB technician had thought of this at the time.
My local indy said it would cost "pennies to fix". :)
SL63 Mark
Wilts
R231 SL63 AMG
Yes it is the parking brake. It is well documented, and very annoying. I have had the same noise, only audible with the roof down. I still get is occasionally. Just ask on here, we will tell you.
sausage
sausage
SL
The rattle is now resolved and it was the parking brake assembly that had failed and caused the noise. A cheap and quick fix that has transformed the driving experience. Parts were about £30.
