Rear shock absorber replacement
Devonian
Just had my 2001 E200 estate MOT'd. It passed but with an advisory note that there was a "fine film of oil on both rear shock absorbers" Obviously it was not bad enough to fail so my questions now are:
Is this a known fault & do you guys think they should be changed?
Do all estates have self leveling suspension, or if not how can I tell if mine has?
Is it a difficult job to do? (I'm a reasonably competent DIY'er)
D
Devonian
Thanks Malcolm That shows it does have self levelling suspension.
I have just checked the price of rear shocks from GSF £95 ea. so that's not too bad. Are they difficult to fit? any tips from someone who has done it?
Thanks, Andy
BlackC55
South coast
C43
Simple nuts and bolts job. Some interior trim needs to come off. Also get some hydralic fluid from MB. The pt number should be on the resevoir.
andy66
Kent U.K
05 c180k with sports pack
not sure if their the same but changed the rear shocks on my 202 c class and it was a fairly easy job..just use a trolley jack to support the suspension when taking old shock out and replace with new one...1 bolt in boot and 1 bolt at bottom of shock
bazzle
Melbourne, Australia
Shocks are not necessarily faulty if they leak a small amount of oil. A slow weep from the gland seal can attract a lot of dust and look very messy. Just wipe it off and keep an eye on it. Most times you will not ever see it again.
Sometimes a shock (or batch of shocks) is overfilled by a few mils. This may cause a leakage under pressure when hot. The seal has to be lubricated somehow and it may bleed thru a layer of dust.
Bazzle
D
Devonian
Thanks to all for replies. I'll do a bazzle suggests and clean them and keep an eye for a while :)
star
Reading
Smart + others :)
No need to change them, if they develope a big leak, u'll notice the resivoir drop. with just a small seepage the resivoir will keep them functioning correctly.
