rear suspension air bags
bembo449
gainsborough , lincolnshire
right , are these difficult to change ? GL 320 of a customer needs OSR so hes asked me to do the pair , any special procedures or is it simply , support the car , unbolt remove air supply pipe and refit ??
thanks
steveq
Dublin
2011 Merc S212 E220CDI Estate; Tesla Model 3; 1965 W113 Merc 230SL Pagoda
I don't know the setup on the GL but on the E Class estate S212 it is as you say above - although it is much simpler to write in a couple of lines than it is to actually do in reality!!
When inflating the suspension units make sure that the wheels are on the ground at about the correct position to ensure that the units don't over extend.
bembo449
bembo449
work carried out this morning , hardest part was getting to the top mount nuts on the shox , rest was relatively straight forward save for the amount of crap that came off everything
steveq
Dublin
Well done. You're obviously a pro and have little luxuries like a car hoist !!
I removed the lower shock bolts when I did my S212 although it might have been easier to remove the top mounts.
malcolm E53 AMG
Did you do a write-up in this I seem to remember one being done?
steveq
Dublin
Yes, I did a write-up.
This is the link to it:-
I am sure there are others too.
bembo449
bembo449
I'm a every experienced DIYer pal , all work carried out off of a trolley jack and axle stands
steveq
Dublin
Ah, OK.
Then very well done on the job.
You threw me when you said that a 'customer' needed the job done.
bembo449
bembo449
Ah, OK.
I did run as a business pal but my job has taken up more time than ever so now I just look after a few select , funnily most of them have MB cars ;)
