Rear Suspension Problems
kelgy
I am having problems with the rear suspension of a 1999 V-class 220 CDI. If it is not driven for a day or two, when I start it up the suspension lowers to about 2" from the top of the tyre, making a buzzing noise from the near side, but not like the buzzing and then the click when it is working normally. If i press the button on the dash, it stope the buzzing but the light on the instrument panel comes onm sometimes steady and sometimes flashing. I then have to turn the engine off, press the button on the dash again for the light to go out, then the buzzing starts again, but it sops if i press the brake pedal, but starts when I release it again. It then seems to correct itself after a short while. Can anyone help?
3narf
High Peak, Derbyshire
I'm having similar problems- see my post below.
I spoke to the garage yesterday and it appears they've fixed it; one of the valves was sticking so they lubricated them all.
apparently, you are supposed to have the system calibrated occasionally which is a main dealer job.
Have you had many more problems with yours? How long have you had it?
K
kelgy
thanks for you reply its only just started since i had the car serviced and had a brake lining changed i`ve had the car two years and done over 30000 miles and its been fine only problem i`ve had is an heater plug snapped off when trying to replace it last summer but local garage quoted £600 but it as started with no problem all winter so i can live with light staying for a min or two just need to change front tyres in the next few months not bad 30k on a big old bus is it how long have you had yours are you happy with it?
3narf
I got it on Tuesday, drove it home then drove it back to the dealer on Wednesday! Total mileage- about 80... :roll:
I've always wanted one- we've made do with a VW T4 for a year but my wife is returning to work following maternity leave, so we needed something a bit quieter/smoother/pokier!
It seems to go really well so hopefully we'll keep it a while.
Is there a workshop manual available for it?
M
mercedes-ben
change it
putting springs in couldnt be easier. mine has been great. ride is better . no more worries . very cheap to do. mb wanted 8 hrs of diagnostics to locate the problem. thas over a grand ! diagnostics ! second hand vito springs £100 . about 1 1/2 hrs work outside my house .
K
kelgy
vito springs
hi could you tell me what parts you needed to change over to springs as i want to change mine but i can`t find anyone who knows what is needed and just been quoted a least £600 for new compresser as mine packed in over the weekend
www.W140.co.uk&www.r129.co
