86 124 300 D Auto
Failed it's NCT(National Car Test here in Ireland) equivalent to MOT.
One area it failed was for Primary Structural Corrosion on the nearside rear top suspension mounting where it fits upto the chassis. NCT tester suggested plating it, but how is it removed, as we opened a bolt which we thought went all the way through to Chassis, no luck, bolt does not go that far up :cry:
Any ideas on how to plate it so as to pass re test??? Another area for failure was a rusted brake pipe on front drivers side, which is routed to ABS unit on passenger's side, can this pipe be cut out & new section spliced in :?: :?:
All info greatly appreciated as always
Billy
Billy
