Rear Tailgate Hydraulic Pump
2010 ml350
Hi every one
I have a 2010 ml 350 the tail. Gate only works when I heat up. With a hair drier when the heat drops off the gate don't work other wise when warm the gate fine the oil. Inside is the right oil the motor works fine so can. Any 1 put light on the matter has I carnt have a hair drier plug in just to. Keep. The motor and oil warm
V6Matty
Newark, Nottinghamshire
I could have sworn the boot is electrically operated on these, I know it is on my E class.
ajlsl600
france
same as that, will have to check.my ml250
M
2010 ml350
Yes the motor is driven by the eclectic but the pump drives the oil I carnt under Stan it when the unit is warm it works but when cold it dosent???
ajlsl600
france
bizarre, oil viscosity ? better electrical connectivity ?
M
2010 ml350
OK thanks guys I'll. Look into it but thank you both for your help
peterws1957
Lancashire
As a matter of interest, why did you think of using a hair drier on the pump? If you've been using it to dry out a water ingress I would suspect an electrical fault. I take it that the fluid level is OK?
M
2010 ml350
Yes the fluid level. Is fine no to start with I thought it was the old oil in the pump so I used the hair drier to heat up to thin the oil and that how it started working again so. I changed the oil to the shell one but it still didn't work when it was cold only when I heat up the pump are the oil but I am. Going to check the conections on the pump look for any thing unusual??
peterws1957
Lancashire
Very satisfying when you can fix a problem yourself. :) I dread to think what an MB dealer would have charged you for sorting that problem. You can see the bill can't you - diagnostics, replace pump, replace oil, test drive, change brake discs and pads......
