Rear Washer Problem
Alybolton@aol.com
New Registration
Have a leak on my rear whasher on my A160 Leaking through headliner.
How do i take plastic rear headliner off please :-? Thats the platic cover at the back of car where the middle seat belt is located.
rascal1003
We had exactly the same problem, with blue washer fluid dripping from the roof!
The rear trim is actually pretty easy to take apart.
If you take the rubber seal off around where the boot panel goes, onto the middle seat-belt panel, you can gently prize the middle bit out from either end.
Just gently feel around the edge to feel where it is secured and it will come away quite easily. I dont remember exactly how it came off but I know I had absolutley no problem at all.
You will probably find that the instantaneous fittings have come apart on the washer hose. You just need to push them hard together until they click into place.
