Rear window demister
paulw9536
Hi all,just bought a 1995 c180 esprite and am having a problem with the rear window dimister,when i turn it on the light lights up but after a few seconds it flashes and the demister fails to work any ideas, Thanks
P
paulw9536
Hi and thanks where would i find the relay for this and is there a way of checking it ?
You do need to check it you have 12 volt on the window, the connectors are on one side behind the C pillar trim, if no 12 volt there you muist work back to the relay
P
paulw9536
Thanks again will check and let you know.
