Suki
- Jul 10, 2005
- Location
- Berkshire
- W251, S211 320 cdi Avantgarde (2005), W202 250 td (now sold), W245 with lots of extras
Firstly I would like to thank all participants of the forum. It is extremely valuable and is the first place I look to when I have an 'issue' with my 124 or 202!
I had a problem that I would like to share with people.
Car: 124, 230e K reg saloon.
Last night the following things stopped working:
Wipers
windows
rear de mister
main beam, when I pull the indicator stalk towards the steering wheel (I could however get the main beam on when I pushed the indicator stalk away from the steering wheel!)
The rest of the car was ok. My first port if call was to check all the fuses. I performed a visual inspection and they all seemed fine. After reading the forum I suspected that the fault was the combination relay. I tried opening the relay and spraying wd40 into the mechanism, but this did not work!
Today I started from scratch and decided change the fuse as a basic prelim check. To my surprise I noticed that the fuse had a nice solid black ring of carbon where the fuse holder touches the fuse! It seems that over time there must have been a carbon build up which got worse over time! I managed to sand the carbon off with a piece of wet and try and hey presto.. all fixed!
Lessons learnt.
Always check the obvious
change the fuse as a matter of course!
don't think that just because the main beam comes on when pulling the stalk to you and away from you uses the same fuse!!!
Wipers
windows
rear de mister
Lessons learnt.
