Remote central Locking problem
Bathbluesman
Southwest
I've just bought a lovely 1991 230ce. It's a great looking car but has developed a problem with the remote locking mechanism.
When I use the remote now, nothing happens. I can use the key to open the doors etc but the vacuum pump carries on for quite a while after. I understand this will lead to failure soon.
Is there likely to be a leak to the system and if so, is there a process where I can locate the place where the leak is likely to be?:(
Dave
B
Bathbluesman
Southwest
Thanks Malcolm, I will start with the drivers door followed by the boot.
Dave
kth286
E320 Coupe 95
The fuel filler flap actuator diaphragm tends to split.
See the unit behind cover in boot.
Cost was about £17 last time.
The CL pump should stop within about 2/3 seconds.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
If you have the thumb wheel to operate the hieght of your headlights (normally adjacent to light switch), this is pneaumatic too so worth checking behind the thumbwheel and the headlight connections.
