Removel of interior door panel on CLK
CTH14
Hi Guys,
My drivers door electric window has stopped working on my CLK 320 W208 and is stuck half way. It would appear that as I can hear the motor running when you push the window switch that it has come out of it's runners or guides.
Does anyone know how to remove the interior door panel to get access to the window workings.
Many thanks in advance.
Ellsy Tanners
Mars
Remove screws behind cover 28 on the pull handle and the little screws on the chrome plate 83 plus the triangle speaker on the top left and the plastic trim around the lock.
then it pops of all the way round with pop clips!!
good luck
C
CTH14
Television, Ellsy Tanners and Bigasotonuk,
Thank you for your replies, have not had the opportunity to try yet due to the great weather we are having but will let you know how I get on.
Once again thanks guys.
dadala
McLean, VA., USA
2000 CLK 320; '96 E320
w208 2000 CLK 320 driver door interior panel
Helo here is a link with all of the fixing points, note there are screws under some of the badges
http://www.detali.ru/cat/oem_mb2.as...GA=722.607&CT=F&cat=45Y&SID=72&SGR=200&SGN=06
Malcolm,
I am unable to pull up your link: http://www.detali.ru/cat/oem_mb2.asp...SGR=200&SGN=06
I have US version and driver's door check strap or stop is not operating, so I need to remove the interior door panel. I hope there are some instructions/drawings for doing so. Can you help?
Thanks,
dadala
I have sent it and you can remove your address in edit
dadala
McLean, VA., USA
Malcolm,
Thank you so much. This should make everything easier.
dadala
PS Any luck getting the pics for removal of the wiper system? Please don't take offense, just following up.
